What does it get you?
1 never ever smelling of gas on hands when working with it
2 consistent quality of fuel this is a big reason either from same can or new cans
3 never ever had a single fuel related issue either in two or in four stroke when using this fuel.
4 two stroke spark plugs and piston domes in any make Sthil Husqvarna Echo never looked any better than they do on this mix and same mix for everything.
5 Never a starting issue ever if hot or cold running engine stored equipment such as generator that may sit 3 or more months I exercise it pull rope it starts and what you need it to do in emergency top off little bit a fuel and stored till needed I never drain fuel from them.
6 shelf life of fuel never had issues but always stored in steel cans helps any fuel.
7 never have winter god awful gasoline in my saws with awful RVP numbers and in cases having to retune them to run on the garbage.
8 pricing for me and value is worth it if I never have fuel related issues and to date I never have.
9 support my local VPracing dealer who I have good friendship with.
