- Messages
- 204
- Location
- Cordova, TN
I was looking at some dino oils today to use after after a run of auto-rx as Franks said the dino chemistry would help seal any oil pan and/or rear main oil leaks I have subsequent to a run and drain of Auto-rx. I noticed that some dino oils are being advertised as high milege with seal conditioners, etc. The only other difference as compared to i.e.regular Castrol 10w-30 is that the high milege version isn't listed as 'energy conserving'. Does this mean a higher viscosity index and/or less friction modifiers?
Does anyone know the real or tehnical difference of these oils against each other within the dino family of oils...another words, a Castrol 10w-30 vs a Castrol 10w-30 High Milege? Any thoughts would be appreciated. Thanks...
