High Mileage Oil Choice?
GA.
With new entries to the High Mileage Oil party - what would be your top choice followed by one or two other high mileage oil choices - if your favorite was not available ? Synthetic or Semi - Synthetic unless you have a Conventional choice that you think stands up really well . Thanks in advance for replies !
South Carolina
M1 HM for syn. Maxlife or Castrol for syn blend. WM has all of these on sale from time to time. Right now Maxlife is 15.88 for 5 qts locally. M1 goes for 22.45 on sale. Right now it is $25-26 for 5 qts.
Great Lakes
Good question. I'm actually pondering the idea of starting to use HM oil my my 530i, in hopes of reducing slight oil seepage/consumption. However, I want to remain in the performance ballpark of the mfg spec oil (LL-01), which is baselined on ACEA A3/B4 spec. So, from that perspective, it's going to be either M1 HM 10w-30 or 40, or the new Castrol Edge HM 10w-40. Valvoline MaxLife used to claim ACEA A3/B4 some time back, but they no longer do, as far as I can tell.
Great Lakes
Actually, M1 HM 10w-30 and 40 claim ACEA A3/B3 only. Edge HM 10w-40 claims A3/B4.
Mahzurrah!
My favorites are Penn HM and Castrol HM since both are still thick for grade which I prefer in a HM oil. Have had the Sebring on Maxlife for years though, excellent stuff.
Texas urban DESERT 9/12 months
Mobil 1 (extreme audio to go) but pennzoil and ML for semi-syns.
Nick1994
$100 site donor 2023
Phoenix, AZ
I'm running Mobil 1 HM in the 1970 Beetle currently and about to change the Jeep Cherokee's oil over to Mobil 1 HM.
VA
M1 HM cut oil consumption in my Grand Marquis from 2500mi qt to less than a quart in 5K mi... After changing to M1 there was probably a half qt loss in first 1500 mi and since has used far less... It was never quite full after change(approx 4/5 full) and I've added approx 1/2 qt, still not down to add and it's coming up on 7K mi...
M1 HM 10w-30 with that 3.5 HT/HS, you hear me?1
Texas
I used maxlife red bottle (semi syn) in a Saturn sc2 with decent results Then went to their white bottle HM full syn. Still not bad and smoking and co consumption went down. Then I figured I would go Mobil since the prices were so close and I prefer Mobil. With this the little Saturn did best on. The Mobil Super is semi syn and a bargain at Walmart. So my choices are: Mobil 1 HM (syn) Mobil Super HM (semi syn)
Oklahoma
I've settled on MaxLife full syn Their 5w30 version meets numerous current specs including SN, GF-5, and dexos I was never really a Valvoline fan, but after playing with the Lubrizol Comparison Tool... the MaxLife was the BEST oil on many different metrics.
