Hello everyone. I just joined but have been reading these forums for a while now. I just got a 1996 Ford Explorer 5.0L V8 with 85,000 miles on it. My plan is to Auto RX the engine and trans and then change all fluids to Mobil 1 synthetic. My question now is I have been reading alot that M1 5w30 is very stable in the summer and with extended drain intervals and better in the winter, but it is common practice to change to a thicker oil as you get to higher miles. Which viscosity should i be going with to make this engine last? Should I go with the 5w30 because it is better at startup and in the winter or should i go with the 10w30 because of the higher milage and not worry about startup or winter? Also I see people talking about cold cranking viscosity instead of pour point but where are they getting this information from. I can't seem to find it on any oil. Thanks for the help
[ September 18, 2003, 03:45 PM: Message edited by: SR77 ]
