How many of you have "flushed" a high-mileage A/T with no prior service history?
What was the outcome?
Me:
2000 Avalon with 311,000 miles. The fluid is pitch black. Calls for Dexron.
No prior service history found except for a 3-4 qt drain/refill by me at the 290-295K mark.
Driver's complaint was: sloppy shifts once the trans is warmed up, presumably from deteriorated (sheared-down) fluid?
I performed a 12 qt "flush" using the new Maxlife ATF/CVTF. Drained the pan, drained the differential, exchanged 8 additional quarts of fluid via the cooler lines. The fluid looks pretty decent now.
I test drove afterwards and did not observing any shifting issues. We'll see how long it lives.
Around 3 qt in the pan. Diff probably holds around 1/2 qt.How much of the transmission was sitting in the pan?
Unit holds 8.5 qt per the Amsoil look-up tool.
Yeah, I did not pull the pan. The plan was to replace as much of the fluid as possible, first, to see if the situation improved. Then we will do a pan drop and another flush after a few thousand miles.I misread your post - I thought you removed vs just drained the pan.
I was asking - how much clutch material was built up on the bottom of the pan and if it had mags how did they look- but you cant know so never mind
Simply - flush uses an external pump in a machine to force fluid through the transmission. Cooler line exchange uses the transmission internal pump to pump out fluid while you add fluid (via fill port, return line, whatever).Would someone mind explaining the difference between a "flush' and "exchange"? Pros and cons of each?
Me:
The thinking is that a flush can dislodge debris and damage the transmission, where an exchange is using existing flow direction and pathway, so dislodging debris and causing problems is much less likely.
Bought my TL with 120k on it and I don't know if it had ever had the fluid changed, it shifted like utter garbage, banging up and down the box. 3x D&F when it got home, and very regular changes ever since. Just turned 185K yesterday.
