- Messages
- 33,974
- Location
- Southern NJ
Would it be accurate to say that RL, S2k, GC and D1 are the oils that contain a higher percentage of esters to PAO then other synthetic oils? ![[Smile]](images/icons/smile.gif)
quote:MK, what happened to your posted opinion that the German Syntec was mostly esters based on its specs and pour point?
Originally posted by MolaKule: I think GC has some some esters, but no where near the level of Redline nor are they the same type. I think GC is using a relatively old formula that Pennzoil used some time ago: 1. Two synthetsized hydrocarbon oils - PAO's and alkylated naphthalenes/benzenes 2. Some 2-ethylhexyl adipate (di-ester) 3. Improved additive package Pennzoils old synthetic formula was superb.
quote:Yes it does, but Motul is so crappy when it comes to giving out oil specs and answering customers' questions that these oils are largely ignored in NA.
Originally posted by cvl: Motul makes some 100% ester basestock oils.
quote:Need partners to create the company and start commercial production ? I'm ready. Anybody else ? The offer is valid until Monday, then all others just shareholders !
Originally posted by MolaKule: In some cases I make my own esters with raw materials because it's cheaper and because purchased finished products are way too expensive for low volume production.
quote:For such thoughts about M1 SS and GC some guys almost excommunicated me from our BITOG church ! Hope you have some info on Motul 300V and would help with the following questions: 1). What can be the reason of quite low Flash Point (COC) and Shear Stability Index of 300V ? The use of some "cheap" esters ? Interesting that according to CEC L-14-A-93 test 300V oils are less shear stable then 8100 or 6100, but the real engine tests show completely different picture. 2). Why do esters oils (namely Motul) usually exibit 1.5 times higher corrosivity then PAO and 2.0 times higher then mineral oils ? ................... 300V 15W-50 ... 10W-40 ... 8100 0W-40 ... 6100 5W-40 Shear stability ......... 4,3 % ..... 8,5 % ....... 1,5 % ........... 1,8 % HT/HS .................... 5,4 ........ 3,93 ......... 3,66 ............. 3,57 NOACK .................... 8,3 ........ 6,0 ........... 9,8 .............. 11,1 Flash point .............. 218 ........ 236 .......... 226 .............. 228 0W-40 : Esters + some amount of PAO. 5W-40 : PAO + some amount of gr.III & Esters It's also difficult to understand what Motul has changed in formulations and why, but until 2000-2002 Flash Points and NOACK were different: 15W-50 232 and 4,0 % 10W-40 218 and 6,5 % The density of oils have been changed too. TYI.
quote:I'd be willing to send a small amount of money along with other members to do testing like this. Anyone wanna jump in? Rick
Originally posted by Terry: Buster, Molakule has listed base oil levels by brand on this site in the past, please search it and post here if you would. VP racing fuels motor oils are nearly 100 % Ester bases. Coconut oil is a part of the mix. Castrol makes a RS 10w-50 that has a large ester component but is limited to certain markets. Aside from Redline the others above contain much less than 40% ester bases. The GC 0w-30 is a unknown unless someone wants to fork over about $400 for a GC burn to determine the oils used. TD
quote:I'm willing to chip in a few bucks!
Originally posted by Last_Z:quote:I'd be willing to send a small amount of money along with other members to do testing like this. Anyone wanna jump in? Rick
quote:The best way to do this would be to Paypal Terry the money directly so he could get the tests done. So before we start doing this, we need to get a show of hands as to who exactly will contribute, and once we have a final number we can figure out how much $$$ to send in. If only 5 people decide to get in, the costs will be too high, but if 20 people agree, or even better, 40, then the cost is very low per person.
Originally posted by Last_Z: Pat, Let's do it....let's create some sort of treasury....we can post the names of the people who have donated money so they know their money is there. It would be nice to see exactly what makes up this GC stuff among others....so let's do it!
