What are you saying? This was the results of UOA's? Magnesium and Boron are oil additives. They have nothing to do with cam lobe wear. Nitration of 26 is within normal limits and 5k OCI's are not extended drains. You also have a bypass filter so you could probably get 10k with ease.
What were your wear metals like iron and lead?
If you are asking if this is a good oil to use then yes, 5k with a lot of idle time should be no problem for an HDEO especially.
