Originally Posted by qdeezie
I just wanted to chime in and say thank you for the OP for creating this post. I absolutely despise taking my vehicles into tire shops to have tire work done. Lately there's always been some sort of problem such as missing custom caps, wheels not torqued tight enough, etc. I knew about manual tire changers that were reasonably priced and could be done at home, but didn't know how I could balance tires at home without spending an arm and a leg. I will be doing further research and purchasing a bubble balancer for sure. Even if it doesn't work out in the long term, it's worth a try.
I've had problems getting quality work done around here. I'm basically convinced that my last couple sets of tires were damaged by the $15/hour nimrod that they called a "Tire Technician Associate". I was watching in the waiting room and the nimrod was using a high-end Coats pneumatic tire changing machine while struggling, tugging and using a leverage bar as well. He had already finished 3 tires when I came back and saw him struggling with the last one. My jaw dropped to the floor. It looked like an industrial accident waiting to happen. I tried to find a manager and go back there but, the manager was nothing more than a senior version of the junior nimrod. A different place did my wife's tires a year earlier and we've had nothing but slow rim-leaks and one tire that seems to have a rumble. I highly doubt if they cleaned the rim beads before putting the new tire on. Also, they lost of the center caps on my wife's car.
Anyhow qdeezie, it's not hard at all to manually change a tire once you know how. The tire platform has to be bolted to the ground or to a sheet of plywood big enough for you to stand on while you're operating the leverage bars. The more rigid the better. I'm sure there are YouTube videos that show how. It basically works no different than the old unit shown in the first post. Long time ago, I could have a tire off, rim cleaned, valve stem replaced and new tire mounted and re-inflated in less than 5 minutes. It's trivial once you know how the machine operates. Some rags, light emery cloth or abrasive scrub pad and a spray bottle with some soapy water is all you will need.
Originally Posted by ruhroh
Is there a trick to using the HF manual tire changer without damaging alloy wheels?
I'll have to let others chime in or, you'll have to wait a week or so. I just got back from HF with both items in hand. I remember the old Coats unit I used had problems with some types of rims. We made some adapters of varying sizes and overcame all the issues. I have a fully equipped machine shop and if I need to make adapters to hold the wheel, so be it.
My wife's car needs new TPMS units on this upcoming set of tires... There's no way I'm going to let the bozos around here touch my cars anymore.
Ray
