This happen last night and perhaps someone can provide some insight as to what happen. I have a suspicion but I'm not sure.
Vehicle: 2003 Ford Taurus SE Wagon, DOHC V-6, ABS but without the factory traction control.
We finally got a significant snowfall here last night. At least 10 inches. The street to my residence is a very steep hill. It was plowed but still snow covered. Well the car clawed and spun it's way up the hill at about 2 MPH. I kept a steady pressure on the gas but didn't allow the tires to spin too much. It finally made it up the hill but as I got near the top the ABS trouble light on the dash turned on.
Put the car in the garage. Both front wheel wells completely impacted with snow/ice. My first thought was that perhaps the snow/ice might have pulled or damaged the wiring to a front ABS sensor. Or maybe snow/ice got into a sensor. My OBD-II scanner can't pull ABS codes so I was running blind.
Anyway, decided to clean out the snow/ice from the wheel wells. And did a "brute force" reset of the ABS computer by disconnecting the battery. No good. Started the car and the ABS light stayed on. Tried it again. Left battery disconnected for about 10 minutes. Still no good. Decided to test drive the car. As soon as I moved forward the ABS light went off and the ABS system reset. I tested the ABS on the snow and it worked. And the ABS light did not come back on. Car is fine today too.
Can anyone with knowledge of ABS systems explain what happen? My suspicion is snow/ice got into a front wheel sensor. That might have prevented the ABS system from measuring wheel rotation which would have tripped a trouble code. Sound reasonable or did something else happen?
