I've discovered that my Buick Encore with a 1 4L turbo engine that has two possible filters for the same engine. One is for the Hengst housing and is manufactured by several companies. The second possibility is for the UFI housing with versions being made only by AC Delco and Fram.
You can likely guess which one I have. The Hengst version made by Delco can be bought for $6.99 all day long at any Walmart. The UFI filter is not at Walmart and is twice as much at parts stores with few choices. It's odd that one of the filters would be so much cheaper and readily available. Not that I'm bitter or anything.
