Help!!!
midwest
Folks, I need your help!!!
Girlfriend's Suburban ('88, 350 TBI) has developed a problem. The thing cuts out intermittently (from what I understand). So far this happened when pulling up to a stop light, and while simply driving down the road. I haven't seen it for myself, just going by what she's told me.
This vehicle hasn't seen any kind of maintenance for at least 3 years now. Well, almost. A couple of years back plugs and wires were changed, and, I understand, there were a couple of oil changes. A couple of months ago I put new plugs (AC Delco) and wires (Borg-Warner) in it. Also replaced fuel and air filters. Shortly thereafter, the fuel pump went. After the pump was replaced, the Suburban ran fine for a while. Now, when I replaced the plugs, I took the advice of the guy from O'Reilly's and set the gap at .045. The gap on the old plugs was also .045. However, the underhood label calls for .035 gap. Therefore, a couple of days ago I re-gapped the plugs (.035) and changed the oil - AC Delco filter, Mobil Drive Clean ("regular") oil (as far as I can tell, that was the first oil change in about 40,000 miles. How's that for and extended drain interval?) The girl said that the Suburban seemed to accelerate quicker after this. Also, found a bottle of SuperTech Gas Treatment in the Suburban, and put that crap in the tank when she bought gas that same day (12 oz. bottle to about 4.5 gallons of gas).
The question is this: which one of those actions could have caused this symptom? Or could this be something unrelated? I'll look at the vehicle tomorrow, so I'll have more information, but right now it seems to me that the spark plug gap could be the main suspect (it ran just fine for God only knows hom many thousands of miles - 123,000 on the clock right now - on .045 gap, and the symptom didn't show up untill the gap was set to .035).
ANY input would be greatly appreciated. Thank you in advance.
Always go back to the one thing you changed before the problem started.
I bet you messed up a plug or two. I would recommend a new set and to set them at .045.
Sounds like the car is about to explode too, you might want to refer her to a shop or you might spend the next year of your relationship working on her car....
Dan
"The thing cuts out intermittently (from what I understand)"
My '97 Silverado started dying seemingly at random (mainly while in reverse). It would immediately restart and run fine. The last time, while driving at night- I found myself coasting in complete darkness - no engine, no dash or head lights. After feeling my way to the shoulder, I determined it was a bad battery connection that was killing the engine. No further problems!
Worth a look. TLAR
Thank you for your responses!!!
Resetting the gap was my next planned move (although I do need to at least visually inspect the vehicle first).
I imagine that "resetting the computer" can be accomplished by disconnecting the battery for a period of time. That theory makes sense too, since PCMs tend to "learn" their environment and even driving styles of the vehicle's operators. Maybe it "got used" to .045 gap, and doesn't know what to do now that the plugs are gapped to spec.
Fuel filter (Purolator) is only a couple of months old
Battery is beginning to look good too, since the current one is an Everstart (if I remember correctly)unit at one point taken out of her son's car (not surprising that the little-bitty half-dead thing cannot handle loads in a Suburban). A few minutes ago I got a call from her . Apparently, the thing died in the middle of the street yet again, and would not start. Wouldn't respond to an attempt to jump-start it, but fired right up after the battery cables were "messed with". Oh, joy.
Vehicle has been in the shop twice since May (fuel pump, tie rod ends). I have a feeling it's about to find a new home at a junkyard
(hence my question in another thread regarding Kia's.)
