Hi all I'm wondering what oil is better for the XR6 turbo produced here in Australia?
I'm a mechanic but I don't quite understand the difference between these three oils http://www.penriteoil.com.au/products.php?id_categ=1&id_brand=1&id_products=2 http://www.penriteoil.com.au/products.php?id_categ=1&id_brand=5&id_products=360 http://www.penriteoil.com.au/products.php?id_categ=1&id_brand=3&id_products=278
I use the semi synthetic 10w-40 on the non turbo flacons until the FG series where I use the recommended HPR5 which is a full synthetic 5w-40 I just put that down to the VVT system and seals. Now I understand that the turbo variant of this engine requires a thicker grade of oil but I was wondering if any one that knows Penrite oils could explain the differences between the oils listed in the link? I was moreso wondering if the ten tenths racing oil would be a better oil to use especially in applications where the owner has turned the boost up.
The engine is a 4.0l (250ci) inline 6 cylinder with a garret gt35 in the early applications then I think they went to a larger turbo. The barra engines have dual cam phasers for variable cam timing but both cam move in relation to each other so in essence they are like a single cam controlled engine.
https://en.wikipedia.org/wiki/Ford_Barra_engine
