Originally Posted By: amodoko
Thank you very much for your response.
How do I know if my engine has sludge? I'm assuming I would need to get an oil analysis done? I am going to be changing the oil myself next week so can I visually see sludge in the oil?
The 2zz isn't one of the sludgers from Toyota. Have you changed your lift bolts? It involves pulling the valve cover. That's a necessary maintenance procedure to check the wear on the bolts. When the valve cover is off, you can see if it's sludged or not.
