Help obd2 codes
New York
I have these 2 codes on my OBD2 reader; P0170 and P0173 for my V6 Mitsubishi 3000 GT; Fuel trim malfunction bank 1 and bank 2.
What does this mean and how do I fix it?
Thanks, Jerry
Could be a vacuum leak, or a fouled MAF sensor messing up the fuel trim. Do you run an open style or oiled air filter by chance? Dirt and/or oil carry-over will foul the MAF p/up in no time.
G/luck
Joel
Sometimes you can get by with a can of electronic parts cleaner and/or a cotton swab. Some MAF's don't fare well to a cleaning. Oiled air filters tend to wreak havok on MAF's.
G/luck
Joel
That's true if you over-oil the filter. If you're careful about the amount of oil you use from now on, you'll should be OK, but MAF fouling from oiled foam filters has been a known issue for quite a while now. Try 90% rubbing alcohol and a cotton swab or a light spray of brake cleaner. You need something that won't leave any residue. Be careful as MAF sensors are very delicate.
Do NOT touch the MAF wire with a cotton swab or anything else. Its very delicate and can easily break. Spray the wire with a cleaner that leaves no residue, and let it air dry.
