I installed a new 2150 carburetor that I purchased from Amazon for my 1986 Jeep CJ7. The out of the box quality of the carburetor is excellent. It installed easily and I have all new vacuum lines.
The engine started immediately but goes to 2,800 rpm so I shut it down for fear of damage.
I believe there is a setting I need to make on the fast idle adjustment and need help!
Additional Facts:
I'm grateful for all ideas and directions you can provide me on how to set this fast idle.
Additional Facts:
- This is the second 2150 I tried from Amazon. The first one did the exact same thing so I’ve concluded I need to make an adjustment for the carb to work.
- The carburetor I replaced is a Motorcraft 2100, almost identical to this 2150. It does the fast ide perfectly at 1,500 rpm but can no longer hold low idle when warmed up even after a rebuild.
