Left the computer on for an overnight download. Went to check on my computer in the morning and it was frozen. Moved the mouse, and the desktop came on and froze in place. Normally, the log on screen comes when you wiggle the mouse. Here is what I've done.
1- Rebooted, got up to the Windows XP logo with the progress bar below. It stayed like that for 5 minutes then it rebooted on its own.
2- Same as above
3- Held power button to shut down and waited 15 mins.
4- Powered on computer and got the same result as #1 above.
5- I was thinking about a new computer now, since this P4 2.4 is almost 4 years old, I went out and purchased new computer.
6- I took out the problem HD and put it in a USB 2.0 enclosure and hooked it up via USB port to the new computer. Powered on the enclosure and XP reconizes it but then the computer freezes where the balloon window in the lower left reads "Found New Hardware"
7- Shut down the enclosure and rebooted computer. Went to Run>MMC>Add Remove Snap In>Disk Management. Turned on enclosure > Refresh. HD does not display on the screen and computer freezes again.
The drive has 2 partitions 1 for XP install and all programs. 2nd partition has all my docs, pictures, and downloaded video clips.
I don't care about the XP install. I just want the photos that were backed up from my digital camera.
I want to transfer those files to the new HD and fully reformat the problem HD and use it as a back up. That is, if it's still salvagable.
I would appreciate any help.
Thanks
