Help me pick lawn mower
TN
Lincoln, NE
I dont' mind my front-wheel-drive Craftsman, but next time I buy a self-propel, it will be a rear-wheel-drive unit.
JTK
Buffalo, NY
Terry, anything that has what you want in the $350 price range is going to be the same in regards to quality. Joel
MIchigan
I thought Toro had nothing but problems with the personal pace? It sounds like the personal pace mowers whether it's Toro, Honda etc. are nothing but problems. I think I would go the regular self-propelled mower. The customers reviews are somewhat misleading because the mowers they bought probably haven't even been used a full season yet. And any new mower you buy is going to seem like a gem compared to the ten year old mower you were using.
Dallas,Tx USA
Best mower I`ve ever used was a Honda. Also,get rear-wheel drive ONLY. Every front-wheel drive mower we`ve ever owned was a total pos.
Bonnyville, AB
I always found I could work faster with a mulching Husqvarna without self-propel, and a rake. I could mow and clean up a double (100 by 120) lot in approximately fifty minutes.
ON, Canada eh?
Don't go by brand of lawnmower, go by the brand of engine and it's design because it will most likely need the most done to it over the years! ;\)
Michigan
+1 Make sure the engine label says H o n d a....
JTK
Buffalo, NY
Gotta disagree with most of that. I do agree that OHV is the way to go (design), but given equal care, the engine is normally the last thing to go on a pushmower. Joel
ON, Canada eh?
I didn't say the engine is the first to go, I said it's the thing that needs the most done to it over the years. (Maintenance and small repairs!) ;\)
tlmprnpg
TN
Thanks on evey comment. They seem mix preference. I used to have 4.5 hp, self propelled, front wheel drive. It's still working but runing rough. I need a new one since I'll have second house.
Michigan
Usually the OHV/OHC engines of any brand are the "better grade engines".
JTK
Buffalo, NY
As far as I know, all small OPE engines require the same amount of maintenance- per manufacturer specs anyway. Dunno of any that spec little/no maint. Joel
Michigan
Lowes has the Commercial John deere 21" with zero turn wheels on yhe front and it's on clearance. It looks well made. 8.75 HP briggs OHV with primer. Its now $397 from $525 Bags/has a side discharge chute that comes down if the bagging chute is removed. Mulch kit? Probably available?
Cleveland, OH
 Originally Posted By: greenaccord02
I'd buy 2 $175 ones and leave one in the box. Use one to do what you need and in 15 years, when it wears out, unbox the other one.
Now that is thinking outside the box!...Not a half-bad idea really...
