- Messages
- 40
- Location
- GA
2001 Berger SS Camaro. 1300 miles total on engine. 6 speed LS1 with phase II heads/cam package (435hp). This car is garaged and only driven occasionally to shows and cruising. I'm using a K&N oil filter and Chevron 10W30 oil based on (the oils spec sheet)and all the good things I've read on this board in the last several months about Chevron oil. My plan was to run dino oil until 2000 miles then switch to Schaeffers 10W30. What do you guys think? I won't skimp on this bad boy!!
