I understand how the higher number (e.g., 20, 30, 40, 50) is rated in multi-viscosity oils, but don’t understand how one determines the lower “winter” number (e.g., 0, 5, 10, 15). What ASTM (or other) standard do you look at to determine these lower weights. For example, I’ve read where some people here have said that Schaeffer’s 700 15W-40 could really rate as a 5W-40 (I hope I’m not misstating this). In any case, I’d like to know how the cold number works in the same way I understand the upper number.
Thanks,
Darren
