Hello to all. I'm new to the board and I must say there sure is a lot of great information here, much more than I realized I needed to know. I certainly will change my future auto oil practices.
However now I have a situation with my 95 Buick Regal that I hope you can help me with.The engine is the 3800 series 1 V6 with about 98K. I've owned and maintained since 22K with past oil changes at about 4/5K intervals. After reading here on the board I suspect with the type of driveing I do here in south-east Pa. winters/summers I really should have changed the oil more often. Oil has been "dino", 10W/30, API rated for the car, usually on sale brands ( Texaco, Quaker State, Castrol GTX now). A steady diet of Fram filters, however now I switched to Pur One with no improvement of condition.
The problem started about two years ago at 78K when I noticed a slight knock and some valve chatter at first morning enginre start-up. Both stoped after 3/4 seconds and only repeat after the car sat overnight. My mechanic gave a listen and thought the cause was a counter-balence shaft bearing and a few valves. Estimated repair cost at $1100.00/? He sugested trying "hitach" to relieve the dry start situation and that seemed to do the job then and over time slowly returned and gotten worse. Now I usually wait about 30/40 seconds to quiet down in the morning but I did noticed this past two winters the engine ran much tighter at start-up. I know the boards thoughts of this type of product and I'm open to any better ideas or suggestions. I'm hopeing to get as many miles or even salvage this engine if I can. The cost of repair, miles on the engine and the questionable condition of the engine I would sooner consider replacement or unloading the car.
I sure would appreciate any advice or ideas. Thanks in advance for your responces. Eric
