JHZR2
Staff member
- Messages
- 46,022
- Location
- New Jersey
Hi,
Per my post in the general OT forum, I just had a diff rebuilt, and in shipping it was dropped. This caused one of the cooling fins, that BMW puts on the diff cover (nothing special, no fancy cover, etc) to bend and break off. Its clear that the diff landed right on the fin, causing the breakage.
Anyway, I was thinking that at least as an interrim solution, since all else appears fine, that I JB weld the fin back on. The metal BMW makes the cover from looks like a cheap base metal, based upon the grains seen at the breakage point. Its not aluminum or anything special. So my question is, how are the heat transfer characteristics of JB weld, and would it make sense for me to JB weld the fin onto the diff (leaving it bent, Im not going to try and fix that)?
Would the JB weld make it more or less like original, or does this stuff inherently impede thermal transfer? It looks metallic.
The fin is a single in terms of placement, only one fin in the particular area where it was located. It was also relatively long, likely to be able to move as much heat as possible from that spot.
How annoying... But how will JB weld do?
Thanks!
JMH
