Originally Posted By: Gary Allan
It really doesn't matter then. If your school of thought is valid ...and I think that it is ..then no matter where you measure it you've got a good view.
Let's go with the hottest point out. Now we'll assume that you're reading it ..and you're seeing how long it stays there. If it stays there for a short time ..we don't worry. If it's there a prolonged time, we assume that it's fatiguing the fluid.
Can we agree, based on just about all of those charts, that there's a "time weighted average" do the degradation? That is, that the shortening of the fluid life is under "continuous" duty at that temp??
So I read the sump. I'm measuring "insult reserve" or buffering. You're reading peak ..or maximum insult amplitude and duration.
Is there really any effective difference?
Well said! And I agree 100 percent, Gary.
Any spot is a good spot to monitor, especially if you understand what may be happening elsewhere... e.g. running 250 in the pan equals "OMG" from the converter out.
A good way to educate yourself is to hook up several sensors with a rotary swx and monitor the temps under various conditions. I had an old diesel Blazer with sensors in the pan, cooler line out and cooler line in. That converter out line got scary to see sometimes! I ended up watching pan temps most often because I knew that the oil coming out of the converter was always going to be much hotter but that the pan was the "buffer," as Gary said. The pan is where the oil will spend the most "dwell" time at a specific temp. When I saw the pan at 200 plus, I knew the trans was getting hot!
