Hi,
A co2 leak test was recently done on my car. (2015 F20 LCI 120i n13 engine)
There are absolutely no issues with the car, no codes, no misfires, nothing.
A compression test was also done and it was perfect.
The fluid in the tester turns slightly green, although in the tests manual it said to pump the tester 5 times the guys doing the test continuesly pumped it for 2 minutes straight.
According to tests manual again green or yellow indicates a HG failure.
Do I have a HG failure? My car has only done 23000 kilometers.
Many thanks
Many thanks
