Hello
Here is my second UOA from Blackstone Lab.
Oil: Havoline 5w-30 SM Synthetic
Filter: Napa Gold(Wix)
Vehicle: 2006 Toyota Tacoma 2.7 4cyl.(2TR-FE)
Miles on unit: 14324
Miles on oil: 4347
Months used: 3
Make up oil: 0
Sample date: 11/18/06
Results:
This Report(14324 mi)/previous(9977 mi)/ universal averages.
Aluminum: 2/3/2
Chromium: 0/1/0
Iron: 3/4/5
Copper: 6/8/4
Lead: 0/0/1
Tin: 0/0/0
Moly: 361/430/145
Nickel: 0/0/0
Maganese: 0/0/0
Silver: 0/0/0
Titanium: 0/0/0
Potassium:1/0/1
Boron: 24/37/30
Silicon: 13/16/14
Sodium: 3/2/4
Calcium: 1715/1885/1904
Magnesium: 5/9/35
Phosphorus: 543/667/685
Zinc: 682/831/828
Barium: 0/0/0
Actual/(should be)
SUS visc @ 210 F 53.6 (56-63)
Flashpoint in F 405 (>365)
Fuel% Antifreeze% 0.0 (0)
Water% 0.0 ( Insolubles% 0.1(
Blackstone comments: "Copper made a nice improvement here, as your engine matures past break-in. The viscosity of the oil was slightly low but thats not hurting anything. No moisture, coolant, or fuel was present. Silicone improved so we think your air filtration/ induction system is working well. Insolubles (oil oxidation due to heat, use and blow-by) were very low at 0.1%, showing excellant oil filtration. All wear was in the proper balance to indicate normally wearing parts at work inside your 2.7L. We have no problems to report. Try 5000 miles next time. The engine can take it!"
My comments: Not too bad. It looks like the engine is pretty well broken in now and the oil is working well.
Miles on oil: 4347
Months used: 3
Make up oil: 0
Results:
Aluminum: 2/3/2
Chromium: 0/1/0
Iron: 3/4/5
Copper: 6/8/4
Lead: 0/0/1
Tin: 0/0/0
Moly: 361/430/145
Nickel: 0/0/0
Maganese: 0/0/0
Silver: 0/0/0
Titanium: 0/0/0
Potassium:1/0/1
Boron: 24/37/30
Silicon: 13/16/14
Sodium: 3/2/4
Magnesium: 5/9/35
Zinc: 682/831/828
Barium: 0/0/0
Actual/(should be)
