Havoline 10w-30, 3,275 mi, 99 Saturn 1.9 DOHC
Texas
This is the 2nd run with Havoline. The previous run (which was not tested) was for 1862 miles--I needed to flush out the "water" which had been found in the previous analysis. The UOAs are listed from latest to oldest. I had been using Schaeffer's but the wife only drives 3.5 miles roundtrip to work daily, so I thought that it was best to just change it every 3 months. I'm not impressed by this report. I may just go back to the 15w-40 and do once per year changes with LC. This run did utilize LC (LOL ZERO oxidation, but the oil is barely a 30w ). Code:
     Havoline           Schaeffer's       Schaeffer's
     10w-30               15w-40            15w-40
     3275 miles           9703 mi           6956 mi
     3 months              1 year           1 year
     8oz LC&2oz/1k mi      no LC             no LC
Cu         11                 25               15
Fe         15                 87               40
Cr          0                  1                1
Al          5                  8                4
Pb          0                  4                0
Mo        489                165               73
P        1101               1294             1126
Zn       1175               1732             1180
Mg         56                 15               11
Ca       2725               3816             2538
A/F       no                  no               no
Fuel      no                  no               no
H2O       no                  .3               no
Si        11                   5                9
Vis     9.46               15.71            12.44
SAE ISO   30                  40               30
Sulfur    19                  38                9
Oxidation  0                  46               25
Nitration  5                  47               36
I am not concerned with the Si, we did take 2 drives, one to Phoenix, and one to Albuquerque. Both had bad sandstorms. The air filter is a K&N; I'll still check it and just reoil it. Anyone ever remember the stretch from Deming, NM, to Tucson, AZ?
Al
Elizabethtown, Pa
Why go back to a 15W-30? Its normal for the 30wt. to shear down. Even if it sheared into the higher 8 cSt. it would be fine. No evidence of higher wear that I see. High irons seem to be normal for this engine. And your cr. and pb. are 0.
uconn1150
Texas
Thanks Al for your response. I was just thinking about that whole thing about changing the oil so often that the wear doesn't really change, or go down for that matter. What I am trying to say, is that if we mulitiply these measurements x4 ( meaning a yearly change) it comes out the same, or yikes, worse.
Al
Elizabethtown, Pa
Yea, I guess I wasn't really looking at your big picture. Schaeffer's really does do a good job over a long period of time. I used to use the Schaeffer's and for some reason just stopped using it. Don't really know why. Maybe your idea is better than mine.
uconn1150
Texas
Not necessarily Al. That's why this site is here; for discussion, experimentation (observation), and analysis. I read another thread where the poster said things have changed; I don't really think so. Ppl leave and then come back; we all need a break sometime. Back on topic. I really don't know what to make of it. I have Havoline back in and will leave it til March. If it tests the same as this run, I'm going back to Schaeffer and try the 5w-40 for 6 month intervals. I service 4 or 5 vehicles and would like to use one weight. Hopefully the LC users will comment on the other numbers.
Alamo, CA
I'd try 5-30 with the 3 mile trips and sheering to a 5-20 is probably in the right direction for those miles.
Spring HIll
"the wife only drives 3.5 miles roundtrip to work daily" I think that, combined with with the water is why wear numbers are a bit high, but is trending downward. You're definitely on the right track by using LC to prevent the sticking ring problem (thus why you have no consumption!).
