Having trouble figuring this out...
Western Washington
Question about our 99 Civic and our 06 Corolla, both with ATs...
Is there a separate differential fluid I need to check/change on these rigs, or does the ATF fluid do double duty?
Nothing mentioned in the Corolla OM about it, and I can't seem to find anything on the web.
TIA~
On the Corolla I'm about 98% sure same fluid.
Not sure on the Civic.
My Subaru has ATF for the Trans and gear oil for the Axle/Transfer case.
Bill
Originally Posted By: Donald
Look at the Amsoil website for capacities for your vehicle. If they list a diff. then you have one.
Yeah, I looked there and none was listed, but I just wanted to make sure I wasn't missing something.
Go over to corolland.com or Toyota nation.There are a couple of guys at corolland who really know their stuff and can tell you whether or not it has a seperate diff.
Originally Posted By: crrdvr6
Same fluid. The diff is in the tranny.
Honda for sure...never had a toyota so I don't know. The CV shafts come right out of the trans...if you remove them, trans fluid will drain out and there is no other reservior.
