Originally Posted by RDY4WAR
A straight grade will have a higher HTHS and higher pressure-viscosity coefficient (most of the time), both which provide more high temperature protection but also increase hydrodynamic drag. For these guys, a 0.5% power gain is far more important than a little less wear.
EDIT: As mentioned above, they are straight grades essentially. No VI. They use some of the "lightest" base oils they can find though.
Ok, so the lube they're using isn't really nothing like what you and I are getting at Wally's..in that they are actually more like a straight grade because of little to no VII's...now that makes a little more sense.
