Tom, sorry to hijack this thread.
quote:
BTW this is nonsequitor; how is it you think water in the intake manifold is going to backwards through a constant-flow injector and get back up into the fuel lines to cause anything to form in the fuel system??????
I don't follow that logic at all!!
Kreigle, I don't think that is happening at all from your description.
I do think that trash or corrosion got to the injectors some how and they clogged not because of FP use but because they were about to fail/clog anyaway.Possibly from both the fuel side and the CC side.
FP is gentle enough by design not to damage injector and other fuel side components. It can scavange smaller deposits but will not carry them past a fuel filter. It cannot remove metal or coatings. It could theoretically clog a fuel filter from other type deposits but I haven't seen it.
The fuel filter having 20K on it is too long on a older car with inevitable trash in the system. I think the filter is allowing trash through.
That trash in the distributor portion could move through and get to the injectors as the clearances in the dist are larger than the clearances in the injectors themselves. There is a centrifugal filtering capabilty in this system for large stuff but I think the Dist sent it on through.
I think that the water injection is a non player on the fuel side but makes me very suspicious about the failed fuel injector, tip condition. Moisture, alcohol and cycles of heating and cooling would have a tendency to affect them negatively. The fact that the intake area and valves are really clean tells me more injected water was used than just infrequently or in small doses.
I also wonder if water vapor from the intake ( if the injection system is malfunctioning) could be getting tracked/sucked in over time to the Fuel Vapor recovery system, or fuel recirc allowing water formation in the system , kind of through the backdoor. Just a theory.
I've seen this when a checkvalve sticks or the vapor canister system fills with fuel and associated contamination.
I am not casting blame but want to make sure the last thing you did or added is not incorrectly blamed for the issue.
I am afraid that you will clog the new injectors and I don't want to see that happen.
You never answered the "shock" treat level of FP used ?
Sincerely, Terry
