Harness for Low Beams Only?
Upstate NY
I drive a LeSabre with independent high beam and low beam bulbs (9005 high/9006 low).
What risks, if any, would I entail by just putting the low beams on a relay harness and leaving the high beams fed by the stock wiring?
Reasons for doing this are: keeping the high-beam DRL's that a full harness would eliminate and not wanting to dicker with the high beams, as they are quite good as is.
update:
After following through with purchase and installation of a harness for the low beams only, I must say I am thoroughly impressed with the amount of light available just by upgrading the wiring. Much more light, longer beam throw, and a slightly whiter light. And all the little refinements present in my Buick still work as they should.
Can I ask where you bought your wiring harness? Also, I would highly recokend the 9012 HIR bulbs. I got mine for $10 at my local John Deere dealer. They are a nice upgrade, see my post in the pictures section.
Off of Ebay. It was a 9006 "HID relay" harness. Designed for providing cleaner power to HID ballasts, with no provision for the high beams like a traditional headlight harness.
Those HIR bulbs look mighty appealing. Maybe a springtime modification.
Update: After 7 months running the harness and 9005 bulbs, everything is still working as it should. Lots of light, highbeam DRL's work fine, and the regular highbeams work fine.
