Age , low mileage, and drying out are probably why it's leaking. You might try a heavier oil , but it looks like you already have it torn down so now the best time to replace the seal. It won't get better by itself.,,,
I have seen Harley seals like that before. Harley Main shaft seals are known to fail. I have had them fail a few times over the years. If I remember right there was an updated seal at sometime.
Maybe contact with some strong cleaner from the outside.
When seals are made the rubber compounds used are cured by heat after being molded to the metal ring. These compounds are kept cool in a temperature controlled
area until ready for use. The composition of the compound ,storage temperature, curing temperature and age all have an effect on the quality of the seals produced. Are
these USA seals?
Originally Posted by fonecord2
I'm trying to figure out if the bearing made contact with the seal or something else caused it to distort. Thanks for the input.
Don't know about your specific question but a bad bearing can take out a seal over time.
these USA seals? It's the stock seal from 2003. The quad seal looked like new.
Don't know about your specific question but a bad bearing can take out a seal over time.[/quote] bearing seemed fine. Isn't marking a grinding noise.
