Gyroscope Oil Rec?
Central Texas
Being this is BITOG & Christmas, I thought it appropriate to ask! Problem is...there's no oil forum for gyroscopes. It is an Asian model, so perhaps "import" is appropriate? grin2 Looks like a metal pin on plastic bushing combination with a touch too much in clearance. I may be able to adjust it out. Definitely a high-speed, very low friction application here. Oil? Grease? Silicone? Graphite? What weight? HTHS? Suggested OCI? MTBF? smile Using a Moto-tool and a rubber wheel, one can get the gyroscope wheel spinning incredibly fast!
Boston, MA
Dry stuff is what the Pinewood derby sharpies use for low drag. You can buy Teflon powder at a hobbyshop. It's used in model reilroad applications.
Chicago IL USA
Zoom Spout Oiler and it's turbine oil seems about right to me. Only takes a drop, then wick up the excess with the corner of a paper towel or tissue.
