My experience with Gunk "10 Minutes" Radiator Flush.
It was the time to change the coolant and some leaking gasket, so I decided to do it myself. The car is 10 years old and no service records. I've got a can of Gunk "10 Minutes" Engine Flush, for a "total" flush.
Browsing the net I've encountered different opinions about keeping the thermostat in or not. I've decided to go for the flush without the thermostat to have the Gunk stuff flowing freely through the whole system.
So, I drained the old coolant, flushed with water and took out the thermostat housing. I've noticed a thin layer of white coating (most likely limestone deposits) on the inner surfaces of the housing. I wonder how the radiator internals look like! Here's where Gunk should work it's magic.
Next, I poured the Gunk stuff in, filled with water, ran the engine for 10 minutes then drained the mix out (by the book). I was expecting lots of debris out. But surprise, there was none! What the Gunk! The fluid was green and clear! Maybe the lime is dissolved in.
Flushed the system with two gallons of hot water. Took the thermostat housing out again only to admire again the nice white coating.
to cut the story short, my advice is: AVOID GUNK 10 MINUTES RADIATOR FLUSH!
New
New
