Quote:
thanks!! yes, the car started with a little poop, and that's the only smoke i see during entire cleaning process...
Interestingly, I used some Amsoil poer foam (not while the engine was running) to just clean the throttle plates and it didn't give me the "white deathcloud" until the second start. Thought it was wierd. Figured it would have happened on the first start, but it probably sucked it into the manifold on the first start then settled.
The real test is to see if your MPG goes up after the cleaning. Are you going to change your oil after this or keep it in (just asking because I used to think you needed to change your oil but some people here have shown that it's not really necessary)
