JHZR2
Staff member
Hello,
Im trying to help a friend tune up his 2002 GTI 1.8T. It is due a timing belt (never done), which I told him to get done right away. It has also never had coolant or MT fluid, though he religiously changes his engine oil with Mobil 1 0w-40 and the engine is clean inside from what I can see.
Anyway, other issues of maintenance aside, he had a CEL, so I checked it for him. It was actually two, one pertaining to the coolant system, which is a common sensor, and another which was regarding catalyst efficiency.
Thinking that catalyst efficiency metrics are tied to O2 sensor readings, I used the software to poll the O2 sensor voltages. I only got one... the Bank 1, location 2 gave me a constant 0.460V, and didnt fluctuate. The Bank 1, location 1, which is at least where the other O2 sensor is on my saab, didnt report, nor did any other banks/locations that I scanned.
My assumption is that likely (unless he has run rich for so long that he burned up his cat) the cat is OK, its just that one O2 sensor is completely dead, the other does not fluctuate, so the ECU wouldnt even know what the catalyst efficiency is.
The plan is to replace the coolant sensor (a $13 part, easy) and both O2 sensors. Id guess that this will solve the CELs and a new cat wont be necessary. Do you think this is likely?
He has 130k miles on the GTI, it runs good, has decent power, and even with a pcv pipe leak and original spark plugs (just changed them today, other than some rust on the threads, they looked good, granted they are Platinum), he is getting 27 MPG at nearly entirely 75 MPH interstate driving. Not that bad in reality...
Your thoughts???
Thanks!
JMH
Your thoughts???
Thanks!
JMH
