Is the arbitrary line between Grp II+ and the lower VI index Grp III’s now blurred?
The API base oil chart has traditionally pegged Grp III as 120 and up VI index. However, lube plants running the new ExxonMobil MSDW technology are now producing Grp II+ base oils and Grp III base oils with VI’s running from 120 to 125.
And the GRP III’s produced with the MSDW technology are lower cost as compared to the traditional 130+ VI base oil Grp III’s, that go thru a 2 or 3 stage hydro-treat process with the associated hydrogen costs.
An example is The Motiva TEXHVI Base Oils – See the typical data.
Typical Data
TEXHVI 70 3.3 cSt 119 VI
TEXHVI 100 4.1 cSt 124 VI
TEXHVI 5W 4.5 cSt 118 VI
TEXHVI 7 6.5 cSt 125 VI
The Motiva/Shell Port Arthur facilty runs the MSDW catalyst.
ExxonMobil Press Release
ExxonMobil indicates that VI’s of 125+ are possible using the RHC & MSDW technology with lower cost, solvent extracted, Grp I type feedstocks.
ExxonMobil Refining Process Options
Typical Data
