Originally Posted By: chevrofreak
Originally Posted By: calvinnnnnnnnn
what is PAO?
Polyalphaolefin, the sole base oil that can be considered Group IV.
There are other more specific names for PAO. For example the following is the chemical name for PAO 4 cSt, which is one of the more common PAO's found in Group IV synthetic motor oil:
1-DECENE, TETRAMER AND TRIMER HYDROGENATED (CAS# 68649-12-7). You can Google the CAS# to examples of this in various MSDS's. Note that the "1" is part of the chemical name.
Other PAO's with a VII of +155 or greater include CAS numbers 68037-01-4 (PAO 6), 151006-63-2 (PAO 7), 151006-62-1 (PAO 9), 163149-29-9 (PAO 40), etc.
When used as a base oil in large percentages, PAO 4 cSt probably has the best combination of viscosity, pour point, flash point, etc for most automotive engines.
For example, typical properties of PAO 4 cSt are a flash point of about 226 C, and a pour point of -69 C.
PAO 40 cSt is much higher viscosity PAO that has a flash point of 294 C and pour point of -34 C. PAO 40 cSt may be fine when used in very small quantities to fortify a Group I, II, or III oil, but would obviously not be appropriate when used in large quantities in a synthetic oil designed for most automobiles.
Here some Group III CAS numbers, but I don't know how comprehensive this list is for Group III base oils used by all motor oil manufacturers:
Hydrotreated paraffinic, heavy - 64742-52-5
Hydrotreated paraffinic, light - 64742-53-6
