Group 1-2-3 , it is really important ??
Quebec Canada
I'm asking this because a Shell technical representative said to me that the oil base is important but a lot less important then what some people think.The performance of the oil is the most important thing to consider.
Can you get the same performance from a group 1 if blended properly then with a GR 3 ?
In all honesty, you can probably get superior performance with a group-I with a top notch additive formulation compared to a group-III with a barely passable additive formulation. That is why the real test in whether an oil is good is in the UOA results!
Hammer
Short answer is no, by definition, Grp III has better Noack volatility, pourpoint, & less impurities.
The development of Motorcraft 5W-20 by ConocoPhillips for the tough Ford specs is a good example of the importance of VI index in a high performance oil.
But....Group I base oils, particularly in the heavier viscosities, are a workhorse in the lubricant industry. Grp 1's will still be a part of many 10W-30 & 10W-40 formulations for SM/GF-4.
