Grossly overloaded Dodge 3500 w/truck camper - frame visibly flexing
Looked up the specs on that slide-in. The current model of it is a Lance 1172, and the dry weight, before you add anything in it, is 4318#.
That's a lot of weight in that truck bed, before you add on what is probably at least 5-1000# of tongue weight.
I wish we had a good picture of the hitch setup. I'll bet that is a butt-clenching contraption on top of everything else.
--Edit--
Silly me, someone makes a hitch for that kind of setup:
  • Helpful
Reactions: GON
4300 pounds is a lot of weight. And that weight is not low gravity weight. A base Mercedes s class is about that weight. Imagine having a s class in the bed of a pickup.
Wow...
It took me a while to better understand the extended trailer hitch. Only after I took that second look, did I get a better visual of how far the slide in actually extends from the end of the truck bed. I did some very amateur line drawings to better see how bad this configuration really is.
The cubbyhole, inside of the red rectangle, holds the generator.
So I have a "Fleetwood Jamboree Searcher" 23' class C RV.
The 1-ton Econoline frame makes it to the rear axle. It's a nice frame, but it ends 6-7 feet forward of the rear bumper.
The coach builder got some 2x4-inch (?) angle iron and built the deck "way out" under the bed & bath section, and hung the water tanks there too. It was hard finding a tow spec for the receiver hitch but I think it's 5k.
No way, uh-uh... and this is something integrated by one party!
The armchair physicist in me wants to see this mess rolling down the road, and flexing, to continue my judgement. From a safe distance.
4wd,
I don't think he should be towing anything behind that extended slide in camper.
If he must keep that configuration and must tow a vehicle, needs to sell the jeep and buy a smart car or similar, tow behind, dolly, or aluminum trailer.
But I sense he purchased on wants, not on needs. That is his choice, but I suspect his choice is a safety to risk to him and others.
There is no vertical load in the methods I posted - flat tow = 4 down
Whereas loads in tensile and compression are easier to manage …
If you look where that Jeep sits on the trailer - he has a very heavy tongue load on a fulcrum of great length …
Those are very capable trucks if used correctly
What is Maurices?
That's an optical illusion; although it appears to be part of the building in the background, it's actually a large concrete slab of the same colour, loaded on top of the Jeep to increase the tongue weight to the desired 75%. (Just kidding ...)
If he has money for that setup, he has money to fix it when it breaks.
If he doesn’t, let the laughter begin…
