Keep us updated, congrats on the progress! 2022 is not a good year to be doing any kind of construction. Contractors are stretched thin for labor /schedules are tight, material in short supply. The focus is definitely not on quality but to get the job done and onto the next one. That's been my experience anyways, and I only had one contractor (slab/foundation) to deal with. It's been a struggle.This seems so long ago that I posted this.
A few days ago I was driving home from Texas and I thought to myself "time to fire the contractor" After months of no movement on the garage I drive up and find this
So hopefully I'll start seeing some progress. I guess the slab guys are lined up to go right after the block guys are done. Fingers crossed.
Not totally sure but the contractor said the rest of the build will be fast. When he promised it by end of June it was the last week of may.Normally how long would it take to build your garage without any delays ?
So I am not sure. it looks wonky to me and I am having a hard time imagining the floor right now. Contractor says not to worry so I wont. Excavators and concrete should be here in the next week so I guess I'll have a better idea.So how far up the block wall is the garage floor going to be? Seem like to pack fill in there, you might blow the walls out if the floor is near the top? I guess in theory crushed 3/4" washed stone is supposed to not need much packing. Or is lots of fill being added on the other side of the block wall as they build up? Roll up doors are handy front and back, so you don't move as many things around as often, so having a "back door" for the tractor/mower/atv is nice and go pretty wide IMO.
I guess your contractor has dealt with your hills plenty times before so he knows what he's doing.
I have a 30x60 hoop barn "shop" on a side hill but I just leveled the area with my tractor and box blade using the material there. I just have a dry gravel floor though, a concrete floor and lift would be nice, but I only have 11' clearance and my fill tends to swell and shrink alot with moisture content! So before concrete I have to put a french drain or something around the up hill side to keep it dryer. I did put 12'x10' high roll up doors at each end so its nice to have a car spot ready for work up front while the atv, tractor, sled can shoot out the back at anytime.
Anyways you'll love your shop and think of a few things you'd change no matter what you do! lol
I know that this block is getting concrete poured into it, supposed to happen next week. I guess that would make it a bit stronger , also there is a pretty deep concrete footer that is under there, they poured that months agoI was wondering the same thing. Here they don’t use block below grade, they’d pour a formed concrete wall. Maybe block is stronger than I realized.
Block is plenty strong in compression, but I wouldn’t want to dump or pack fill next to one unless you’re really careful. Interesting sequence for construction.I was wondering the same thing. Here they don’t use block below grade, they’d pour a formed concrete wall. Maybe block is stronger than I realized.
guess it's called a t type foundation. I had to look it up. I think it is because technically this is not going to be a heated space and the ground has potential to freeze.Block is plenty strong in compression, but I wouldn’t want to dump or pack fill next to one unless you’re really careful. Interesting sequence for construction.
Here we can use block for foundations and it’s fine even with heated basements usually.I was wondering the same thing. Here they don’t use block below grade, they’d pour a formed concrete wall. Maybe block is stronger than I realized.
A t-type foundation is what is used here but I’ve never seen it done with blocks. Not sure how well they’d waterproof for a foundation/basement vs a solid wall. Post up some more pics when they get the grade where they want it.guess it's called a t type foundation. I had to look it up. I think it is because technically this is not going to be a heated space and the ground has potential to freeze.
3 Types of Concrete Foundations - Slab on Grade, T-Shaped, Frost Protected - Concrete Network
Information on the 3 types of concrete foundations: T-Shaped, Slab-on-grade foundation, Frost Protectedwww.concretenetwork.com
