Well, I'm better off with Mercruiser but I would think that the Quicksilver High Performance Gear lube would be idea for that outdrive too. It's synthetic and is required for the Bravo drives and can be used on outdrives with dog clutches, such as the Alpha series. For the grease, look around in the back of the outdrive on the water side, there should be grease zerts located all over. They may be covered up with a plug. For that you can use good ol' waterproof grease like the Schaffers brand, forgot the actual name, but it's waterproof and has a butt load of moly in it. Moly is good for high pressure areas.
