Anyone know of a way to grease urethane suspension without disassembling? I was thinking a syringe w/ an oil/Grease mixture. Squeaking front end driving me nuts......Any special grease type???????
If you have a grease gun, this needle adapter might work. After you load the link, scroll down to page 77, and check out adapter #82784. It has a zerk inside the sleeve that is not viewable. That is how it attaches to the grease gun fitting. I know this because I have one of these. This adapter is actually designed to inject grease into a hole that has no zerk installed. It may or may not work for your application. If it doesn't work, at least now you know of its existence.
