Hello,
I am looking for grease that will provide good lubrication and corrosion inhibition in a ball bearing that is rubber sealed but nonetheless somewhat exposed to rain and gritty salt water which is sprayed at it and can sometimes pool around it. The bearing is relatively slow moving at about 50-200rpm and is also subject to shocks. For that reason I was thinking about a grease that is relatively fluid in use and that has a high base weight oil so that it provides a good oil layer at low speed and also keeps the seals wetted. Nonetheless I am assuming that some salt water will eventually make it past the seal and would like the corrosion inhibitors to protect the bearings for a period when this happens until they can be overhauled. The bearing does not have a grease port so I can't just purge the grease periodically, the unit has to be stripped down to allow regreasing unfortunately.
I've been suggested to look at greases like SHC1500PM which is for paper mill equipment. I suppose that some marine/agricultural/mining greases might also fit? I am finding it difficult to determine which grease have lots of corrosion inhibitors and which ones only have a little because lots of greases specify they contain some but never it seems the relative amount.
Can I rely on the ASTM salt water spray test or any other specifications?
