I’ve hopped up my sons Power Wheel, and interested in re-greasing the gearboxes. Others in the Power Wheel forums have done this in the past with good effect on noise and performance.
I figured I would try to get a detailed recommendation on the type. The gearbox is a 4 stage reduction with Nylon gears. The motor output is metal, and the shafts are fixed into a plastic case. I included a photo of a broken box.
The two failure modes seem to be shaft overheating and melting through the case (what happened to me) and stripping of the 1st gear. Since both these things are happening on the fast side of the box, I think heat could be an issue.
A reputable power wheel modding company sells a red grease. What kind of grease would you recommend?
Thanks!
Thanks!
