Been using Valvoline Synpower grease for the clutch release throwout bearing and sleeve etc. Just curious if there is something better out there or if this is perfectly adequate?
There have been some folks who've had problems with the clutch rlelease bearing failing, heat welding to the shaft/sleeve etc. Haven't had too much experience with the different kinds of grease so I figured this would be the perfect place to inquire.
BTW, the car is a modded Mitsubishi 3000GT VR4 running an RPS full carbon faced twin disc race clutch.
Been using the Valvoline Synpower for all kinds of greasing, clutch release bearings, tierod ends, tranny output shaft splines (the AWD drivetrain has an output shaft from the tranny that goes into the transfer case to the rear wheels. The splines of the output shaft tend to rust after a while).
Any advice or recommendations would be appreciated.
Max
