And I quote;
Originally Posted By: Donald
Also we should tell (warn) that doing your GF's vehciles brakes may or may not be a wise move. You of course will get blamed for anything that goes wrong, even 10K miles from now.
Are you prepared to replace caliper? The piston might not go back in properly or you snap the bleeder screw.
A brake job can get costly quickly when calipers need to be replaced.
Well, supposed to be a simple brake job, so the drivers side was textbook perfect. No issue at all.
So on to the passenger side. Right when I started cracking the lug nuts, they all didn't feel tight. Real galled feeling. Got them all off but one, which backed out a few turns and then that's all she wrote. I worked it for about 20 minutes back and forth, but it wasn't happening. Was able to drive the car to Midas and they were able to break the stud off.
Went to the dealer for a stud and lug nut, but I guess the studs aren't something that can be done in the driveway. Pressed in bearing/hub.
At least we still have a few threads that the lug was able to catch. Some were buggered up, I cleaned the threads and used a small amount of anti seize on the rest as they felt real bad.
All in all, the car is drivable, but not sure what the next step is. She may take it back to the other Midas that took her wheels off a couple of weeks ago (impact of course) and see if they can replace the stud.
I think this is the last time I do work on anyones car...
