Hello. Over the last week I have been trying to figure out a good oil for one of our cars. Its a 71 Dodge superbee with a 440 in it. Its pretty built, running 13:1 compression, alum heads, and a large cam. Last time it was on the rollers it pulled 805.7 on the 200 shot. The car is mostly use for mild street driving with very little W/O and rpms never over 5k.
It is running a fully soild roller valvetrain so high zinc for the cam isnt a huge deal. motor is setup and does well on a 40 weight and runs right at 45psi warm, 75-80 psi at 4k. Currently its been running rotella 15W40 and has about 3000 miles on the engine. While the rotella has been doing a good job i feel there has to be a better oil out there that isnt crazy expensive that will protect this motor. While it does see the drag strip, its a maybe 4 passes a year due to having devoted drag cars.
The biggest issue I see is the high hp, the leaded fuel, and the fact that it sits 3 days+ out of the week and around 9 months in the winter due to SD winters not being the shortest. It does stay in a heated garage and sees yearly oil changes.
So in everybodys BITOG opinion what would be some good oils to run? im planning on changing the oil this weekend seeing as the current fill has seen a few carb issues and i want to get the gas out of there. Also i can post some pics if you guys would like
Thanks Brent
Thanks Brent
