My Phaeton had dual H9 AGMs in the trunk.Holy crap. I was actually going to do an H4 that is under 30 pounds; Jettas with the 1.4 come with it.
There is no need or reason to "over battery" and economy car. The H6 is the same as what's in my Atlas with twice as much electronic stuff and auto stop/start. The H5 I had originally/OE would have likely gone 5 years..I just changed it b/c I was doing 2 of my other cars and was at Costco.more weight = more lead + more starting power + prolly lasts longer if kept properly charged. not a fan of overpriced AGM's if a similar flooded battery fits + battery power shrinks in the cold, again MORE is better IMO!! most people could loose 10 or MORE lbs + be healthier as well while saving $$$ on todays overpriced food!!
The H5 AGM is 40 pounds.Isn't a lot of that weight because it was an H6 versus an H5? AAP says their Die Hard AGM is 39.6 lbs.
Interesting too because i just dropped an H7 in our Cruze, the lead acid was only 2 pounds lighter than the AGM (if you can trust the WM site).
Like on my bicycles, every oz counts my friend. No reason to slug around 10 extra pounds up front.Just lettin' you know. If the back wheels ain't off the ground, the battery ain't 2 heavy.
I had to replace a fuse in my Tundra that allows another 0.5v of charging when I switched out to an AGM. Super easy to do although with CV-19 it was not easy to get ahold of one which I eventually found in Australia. You can also hook it up to a charger that can handle AGMs ever now and then too to top it off.I thought you weren't supposed to put AGM where a traditional lead acid was before, unless you also tell the vehicle you're doing that?
Because RACECAR that's why.Why would ten or 12 pounds make any difference in a car
Picked up an Interstate H6 AGM battery for my Sportwagen back in February. My car came with an H5. Swapped it out for another H5 Die Hard from Advance today to drop some weight up front...my car is v. basic and has no reason for the AGM monster. H6 AGM = 44.6 pounds....H5 lead acid = 35.5. Almost 10 pounds saved! I'll just sell the Interestate off.
Lol. Know how it is. I used to ride a Dura Ace bike. The deep cycle AGM battery, in my boat, is 17 years old. I put it on the AGM charger after use. YmmvLike on my bicycles, every oz counts my friend. No reason to slug around 10 extra pounds up front.
An AGM battery can be used in place of a traditional flooded battery in almost every case. The general advantage is longer life, never having to add water, and it presumably, has less risk of leaking. Many car makers are providing them as OEM standard due to higher demands put on the battery with so many power robbing accessories and start/stop engine features.I thought you weren't supposed to put AGM where a traditional lead acid was before, unless you also tell the vehicle you're doing that?
