Gonna try M1 Truck & SUV in my 8.1 gasser
College Dorm...
quote:
Originally posted by Stewart Fan: There are very few UOAs done on the 8.1 liter gas engines from GM. All the UOAs have been on M1 10-30 IIRC. Although my truck calls for a 5-30/10-30,I'm going to try the 5-40 M1,and post a UOA in a few months. I don't see an issue with the higher viscosity. A COLD winter night around here is 25-30* Fer. The average overnight lows are around 40*. Do you see any reason not to try it?
Nope...in fact, I strongly recommend that you run a 40-weight in that engine!
Stewart: Is your Vortec 8.1 one of those infamous oil burners? In that case, the Mobil 1 Truck & SUV 5W-40 (Same as Delvac 1 for commercial trucks) will HELP a lot. I know in my commercial equipment, oil consumption decreases around 50% on average. I will also be switching my truck to M1 T&S in April or so. If Holden in Australlia can run LS1's with xW-40 and xW-50 oils no problem, with MUCH lower oil consumption, we can too. FWIW: here is the difference viscosity makes in my 2000 GMC Sierra with Vortec 5.3 V8: Mobil 1 0W-30 1 quart every 4,200 miles Mobil 1 5W-30 1 quart every 4,800 miles Mobil 1 10W-30 1 quart every 6,800 miles I don't think there will be any negative fuel economy hit. I used to have a 1992 Honda Prelude SR that I bought new. In summer of '94 (Or was it '96??) I put in Delvac 1 5W-40 before a very long road trip. I went to Lost Wages Nevada, then visited some relatives in Santa Rosa CA, then down to LA, then across the South to Disney World , back across the South to I-35, then North to home. There was NO difference in fuel economy. The motor seemed a little quieter and smoother. Not an oil burner to begin with, there was a DRAMATIC difference in oil use: 15,000km on the oil and the level was down about 2mm on the stick. Jerry
I wouldn't call it an oil burner. It does use some oil,usually about 1/2 qt. in 3500 miles. I don't consider that unreasonable,because I work my truck alot. I tow our boat almost every weekend,and then our travel trailer the times I'm not towing our boat.
Here is the results of my 8.1 L Avalanche First 6000 miles on dino 5w30---no burn at all Changed to Castrol syntec 5w50--burned 1qt/300 miles Castrol syntec 10w30--1qt / 600 miles Tech 2000 10w30--- 1qt / 800 miles back to Dino 5w30--no oil burn at all Now on GM oil burn watch--rather embarrassinng no burn Figure that one fellas!?? Clare
