I have a '93 Suburban with a 350 TBI engine and approx 170K miles. The truck runs well, except for during certain circumstances the engine will cut out. This generally happens at highway speed, when increasing the speed and load of the engine (not enough to cause a downshift). It feels like the engine is shutting off then coming back on but very quickly. Under most other driving it's fine, including very heavy throttle.
At first I thought this was an ignition miss, but after checking all my ignition (and replacing a few parts), the problem still exsits. I believe that low fuel pressure can cause a symptom like this in these GM TBI engines.
IFthe fuel pressure is low, does anyone know how to determine if it is a weak pump or a bad pressure regulator? Both are original in the truck, and I would prefer to replace only one at this time.
