Quote:
"There's so many different ways to approach fuel efficiency. It doesn't have to come through one huge break through smash hit."
Uh, lets make cars lighter and use smaller engines
Lets offer TDi/CRd/CDi diesel engines
No smash hit needed. Maybe a whack in the head with some common sense
For the first time, the Hummer H3 will be available with a V8 engine.
Yeah, thats the solution
Noone remembers the 2-stroke Orbital?
I do and how close Chrysler came to producing a more conventional 2 stroke and .....
Largely agree with your observations here - esp size and weight and if you will , size and weight
choices .
However , as unlikely as it sounds in terms of feasibility , if you can make (the big ) pigs fly ...... at least here , ..... thats gonna sell ..... in more ways than one .
Interesting , this is the second botched article I've seen concerning something like this from a normally reliable source in the last month or two .
Well ,anyway ,contrary to the impression conveyed in the linked article this HCCI approach like every other one to date over the last thirty years from the 30 to 45 or so OEMS , Universities , Technical Institutes , etc that I am aware of having worked on this - alternates between sparked ignition and 'heat' ignition . Its not a gasoline fueled diesel in more ways than one .
BTW John Browning , Toyota would not be on that list until relatively recently and they would occupy the last position for the Johnny Come Lately crowd - tied with Hyundai .
Anyway , this technology along with some others concerning conventional IC 4cycle. 'tech' is part of what hybrids and clean diesels alike have to look out for in the interrium distance . Roughly speaking , if you can get 2/3s - 3/4s the benefit for a 1/4 or a 1/3 of the cost ...... now 'stack' a couple together ..... well it sure as heck ain't going to be over until its over .
An interesting example is the MB 1.8L I4 installed in the F700 which is a 'S' class sized vehicle .
- Mercedes-Benz is to unveil a concept car called F700 - a 'radical' proposal for a large luxury car - at the Frankfurt Motor Show.
The F700 will showcase Mercedes' innovative DiesOtto engine, a turbocharged 1.8-litre, four-cylinder unit that combines diesel-style automatic ignition with a conventional petrol spark plug system on start-up and under heavy accelerative demands. This engine is capable of a 235bhp output, but with near-40mpg fuel economy -
Has a huge fat flat torque curve - decent performance as well .
I believe another article puts the Fuel economy number for USA market at 31.5 - 32 mpg .
Soooo ....maybe downsizing won't be so important after all ....unfortunately .
( Just gotta imagine this in something smaller ..... )
Here is an older link from autoblog green that covers alot of the above including GM's HCCI and one perspective on why 2 cycle didn't materialise .
http://www.autobloggreen.com/2007/05/15/...wertrain-resear
